File->Revise shortcut creating ?
Hello
How to create a shortcut for basic Revising (like CTRL+R)  ?
- Now I go to Teamcenter->File->Revise.
Re: File->Revise shortcut creating ?
First, 'Ctrl+R' is a shortcut available to remove BOM line in Structure Manager.
In My Teamcenter, If you want to revise a item you have to select item revision and File > Revise. This is OOTB process.
You can add 'Revise' icon to the toolbar. Right click in toolbae area to open 'Customize Toolbar' dialog and add the revise to the desired toolbar folder.
Matter of choice and few clicks. With customization it may be possible, not sure.
Quick solution without any configuration for RAC --> ALT+F+R+ENTER.
You can also have a RAC plugin with a UI biding in your plugin.xml
<extension point="org.eclipse.ui.bindings">
        <key commandId="com.teamcenter.rac.open"
                    schemeId="com.teamcenter.rac.scheme" sequence="M1+alphabet"/>
</extension>
M1 is for CTRL key.
I havent tried it, but it must work.
If you ran out of alphabets, you can use SHIFT (M2) or CTRL+SHIFT (M1+M2)
There are lot other combinations you can play with. You can refer to any of the plugins for more examples
Mahendra
Where to enter this code in Teamcenter ?
</extension>
Hello
That should go into your plugin.xml of your custom portal plugin
please note that the commandid for revise is com.teamcenter.rac.revise
Mahendra
