FileManagementUtility Soa C# Download file
I'm trying to use FileManagementUtility  in visual studio2015 but I got an exectption.
I'm working with Teamcenter 10
erro3.png.
my code:
            try
  FileManagementUtility fMSFileManagement = new FileManagementUtility(Session.getConnection());
            catch (Exception ex)
I have  added  TcSoaFMS64.dll and FCCNetClientProxy4064.dll  to the debug folder but still not working.
3 REPLIES 3
Re: FileManagementUtility Soa C# Download file
FCC looks for the dlls through environment variable PATH.  Make sure that %FMS_HOME%\lib is added to PATH.
Preferable to add at the beginning as the PATH value may get truncated if it's too long.
Thanks :) but this doesn't help. I still have the same exception. Do you know another alternative ?
If you are using Teamcenter 10, not sure why your TcSoaCommon version shows 11.2.0. Also there seems to be an entry showing .Net version 4 being used. TC10 does not support .Net 4.
.Net 4 support starts from Tc11.
Also, this might not be a reason for this problem, but FYI: TC 10 supports MSVisual Studio 2010 SP1 Standard & Professional Edition
