FileManagementUtility TC10 exception in FCCNetClientProxy64.dll
I'm working with Teamcenter 10  to download a BOM.
I'm trying to use FileManagementUtility  in visual studio2015 but I got an exectption.
 try
  FileManagementUtility fMSFileManagement = new FileManagementUtility(Session.getConnection());
            catch (Exception ex)
InnerException = {"Could not load file or assembly 'FCCNetClientProxy64.dll' or one of its dependencies. The specified module could not be found.":"FCCNetClientProxy64.dll"}
4 REPLIES 4
Re: FileManagementUtility TC10 exception in FCCNetClientProxy64.dll
do you have this dll in your tccs\lib folder?
Hi
Yes
As xplm2005 has mentioned if you add this lib to your system PATH variable you should not get this error...
Thank you for your helping,
I solve the problem by using this construcor.
FileManagementUtility fileManagementUtility = new FileManagementUtility(Session.getConnection(), "myip", new[] { "" }, new[] { "" }, "C:\\");
