03-22-2015 11:02 AM
I am new to this forum. After reading some of the post, I found out this is quite handy. I hope someone in this group can give me advice if this can be done.
I am looking at a solution in Teamcenter can automatically generate dxf file and Step file through workflow process. Did any one experience on it?
I am using NX 8 with Teamcenter 8.3. Going to NX9 with Tc10.1,
Andy
03-23-2015 06:07 AM
You need to set up and configure a dispatcher server to do the translation in the background.
After this is working, you can create translation (dispatcher) requests through workflow handlers.
Employees of the customers, together we are strong ;)
03-23-2015 09:19 AM
Thanks for your response. Yes, I have used dispatcher already and generate CGM files and JT files. Is there any OOTB tools i can use to translate dxf and step? I found an article to use "EPM-run-external-command" to generate CGM --> PS --> PDF using "Prepare" Utility in TC Vis. However, I don't see how it can convert to dxf / Step.
03-23-2015 10:30 AM
There are STEP and DXF translators included in the dispatcher service, you just need to install and configure them.
You can use the dispatcher_create_rqst utility, shipping with Teamcenter, to create translation requests.
The Teamcenter help library contains information about it in the utilities reference.
03-23-2015 10:41 AM
I dont see translators are available. Is it new in Teamcenter 10.1? We are still in Teamcenter 8.3.
See attached Translator Option in Teamcenter Install.
03-24-2015 01:44 AM
Seems that this has been implemented by our CSR, so you would need to contact them for the exact steps.
The external translators can work with Tc names like @DB\{ItemID}\{ItemRevision}, so you just need to create the batch file and add the definition to the dispatcher.
04-02-2015 01:47 PM
