12-01-2016 09:39 AM
public void xGetItemAndRelatedObjects(string itemID) { itemID = "P00000333"; DataManagementService dmService = DataManagementService.getService(Session.getConnection()); GetItemAndRelatedObjectsInfo[] getInfos = new GetItemAndRelatedObjectsInfo[1]; GetItemAndRelatedObjectsInfo getInfo = new GetItemAndRelatedObjectsInfo(); ItemInfo iteminfo = new ItemInfo(); getInfo.ClientId = "MYTEST"; iteminfo.ClientId = "MYTEST"; iteminfo.UseIdFirst = true; AttrInfo[] attrInfos = new AttrInfo[1]; AttrInfo attrInfo = new AttrInfo(); attrInfo.Name = "ITEMID"; attrInfo.Value = itemID; attrInfos[0] = attrInfo; iteminfo.Ids = attrInfos; getInfo.ItemInfo = iteminfo; DatasetRelationFilter[] filters = new DatasetRelationFilter[1]; filters[0] = new DatasetRelationFilter(); filters[0].DatasetTypeName = "DWG"; filters[0].RelationTypeName = "IMAN_reference"; getInfo.DatasetInfo.Filter.RelationFilters = filters; getInfos[0] = getInfo; GetItemAndRelatedObjectsResponse response = dmService.GetItemAndRelatedObjects(getInfos); // error in DOM parsing GetItemAndRelatedObjectsItemOutput[] outputs = response.Output; }
need some hlp, cannot find my mistake in prog
TC11 Vs2015
I'm trying to get the infos for a itemId. It works until I call the service.getitemandrelatedObjects.
there is the error 'error parsing DOM' . Seems the getInfo-class is not correct.
Sorry can't see my error.
Thanks for any help
12-01-2016 10:33 AM
As I did something similiar I defined RevInfo and I do not see information about the revision in your code. Maybe worth giving it a try.
xtof
12-01-2016 12:01 PM
thanx, haven't seen, the is also a DatasetInfo
I added this to the prog
Snippet
public void xGetItemAndRelatedObjects(string itemID) { itemID = "P00000333"; DataManagementService dmService = DataManagementService.getService(Session.getConnection()); GetItemAndRelatedObjectsInfo[] getInfos = new GetItemAndRelatedObjectsInfo[1]; GetItemAndRelatedObjectsInfo getInfo = new GetItemAndRelatedObjectsInfo(); ItemInfo iteminfo = new ItemInfo(); getInfo.ClientId = "MYTEST"; RevInfo refinfo = new RevInfo(); refinfo.NRevs = 0; getInfo.RevInfo = refinfo; DatasetInfo datasetinfo = new DatasetInfo(); getInfo.DatasetInfo = datasetinfo; iteminfo.ClientId = "MYTEST"; iteminfo.UseIdFirst = true; AttrInfo[] attrInfos = new AttrInfo[1]; AttrInfo attrInfo = new AttrInfo(); attrInfo.Name = "ITEMID"; attrInfo.Value = itemID; attrInfos[0] = attrInfo; iteminfo.Ids = attrInfos; getInfo.ItemInfo = iteminfo; DatasetRelationFilter[] filters = new DatasetRelationFilter[1]; filters[0] = new DatasetRelationFilter(); filters[0].DatasetTypeName = "DWG"; filters[0].RelationTypeName = "IMAN_reference"; getInfo.DatasetInfo.Filter.RelationFilters = filters; getInfos[0] = getInfo; GetItemAndRelatedObjectsResponse response = dmService.GetItemAndRelatedObjects(getInfos); // error in DOM parsing GetItemAndRelatedObjectsItemOutput[] outputs = response.Output; }
but no luck, error stays the same :-(
12-02-2016 03:39 AM
Please change this line
to
attrInfo.Name = "item_id" ;
"item_id" is the property internal name format defined in Teamcenter.
12-15-2016 11:04 AM
12-16-2016 02:00 AM
Hello Wilmos,
I will just try to hit the nail in the darkness. Please, check into the site preferences that 'TYPE_DISPLAY_RULES_list_types_of_subclasses' includes 'Item' into its list of values. If not, add it to the list and try your code again. Maybe it helps.
Ramon Talavera
12-24-2016 04:54 AM
Had one more look at my Java code. First I got the same error than you. After setting it up one more time I was able to get the information.
m_dmService = DataManagementService.getService( AppXSession.getConnection() ); String itemId = "000794"; String revId = "A"; AttrInfo[] attrInfo = new AttrInfo[1]; attrInfo[0] = new AttrInfo(); attrInfo[0].name = "item_id"; attrInfo[0].value = itemId; ItemInfo itemInfo = new ItemInfo(); itemInfo.ids = attrInfo; itemInfo.clientId = "itemInfo1"; itemInfo.useIdFirst = true; RevInfo revInfo = new RevInfo(); revInfo.id = revId; revInfo.nRevs = 1; revInfo.clientId = "revInfo1"; revInfo.useIdFirst = true; revInfo.processing = "Ids"; DatasetInfo dsInfo = new DatasetInfo(); dsInfo.clientId = "dsInfo1"; dsInfo.filter = new DatasetFilter(); dsInfo.filter.processing = "None"; GetItemAndRelatedObjectsInfo[] itemAndRelObjInfo = new GetItemAndRelatedObjectsInfo[1]; itemAndRelObjInfo[0] = new GetItemAndRelatedObjectsInfo(); itemAndRelObjInfo[0].itemInfo = itemInfo; itemAndRelObjInfo[0].revInfo = revInfo; itemAndRelObjInfo[0].datasetInfo = dsInfo; itemAndRelObjInfo[0].clientId = "itemAndRelObj1"; // NamedReferenceList namedRef = new NamedReferenceList(); // namedRef.namedReference = "TEXT"; // namedRef.ticket = true; GetItemAndRelatedObjectsResponse resp = m_dmService.getItemAndRelatedObjects(itemAndRelObjInfo);
HTH,
xtof
