Re: Getting the parent of a Folder using SOA calls
It does seem reasonable to me, I will update my code and inform.
I think that info.relation should contain the correct value, that would make coding much easier.
I will try to get an answer from QTAC.
Thank you very much Sir!
A year later...
The solution.
Not having BMIDE infront of me right now, I think Folder.contents is a Runtime property, i.e server code is executee to obtain the contents, rather then following a relationahip.
You are right, OpenPlm.
