Hierarchy number multilevel structure manager
I want to have a multilevel hierachy number column in the structer manager
For example:
1
1.1
1.1.1
1.1.2
1.1.2
1.2
1.2.1
1.2.2
etc.
I tried this with Find No. or Occurence Order Number. But that is not working with multi level BOM.
Re: Hierarchy number multilevel structure manager
This will have to be a run-time property. This can't be static information - keep in mind that subassembly can be used used at multiple locations and multiple levels, assembly structure will change depending upon the revision rule that you select, assembly structure will change the moment someone revises any sub assembly (and make changes).
Thanks and Regards
Yogesh Fegade
