Home - How can I reorder my folders
Is possible to reorder the folders in home or reorder the items within a folder that I have created in the Home tab? I have asked and have been asked this question from different users many times with no real answer or good reason why this feature wouldn't be included in Teamcenter.
Re: Home - How can I reorder my folders
The tree view can be ordered ascending or descending through Edit => Options => General => UI => Tree display order.
Employees of the customers, together we are strong ;)
I appreciate the reply that is nice to know wasn't aware that you could do that. That's not exactly what I'm looking for though. Can you reorder items? For example can you make the first move down to be the 3rd, move the 3rd down to be the last (without using cut and paste). Just manually reordering the items.
Yes, it's possible.
I think it's different on different versions of Teamcenter.
Here's how to do it in Teamcenter 8.3
Make sure you have the "Tree display option" mentioned by Stefan set to "Not Sorting"
Select the object you want to move, then select the down pointing triangle in the upper right section of your tree section (see image)
Select the move option, and you will see the up, down, top & bottom options to move your object.
I hope this helps.
Thank you this has been very helpful!
Jacosta
Additional Refferrence...:smileyhappy:
Sudikin
NX10-SW2014-Integrator
Can anyone else help us on this? No solution so far...
We can not proceed as mentioned below as we are using TeamCenter 9...
@jAcosta wrote:
Yes, it's possible.
I hope this helps.
Lesser known option, Really useful! :smileyhappy:
