How Teamcenter will get integrated with Oracle
Builder
Builder
Hello Team,
i have one doubt while installing TC we will install Oracle DB first and then will proceed with Teamcenter installation.
i want to understand how Oracle DB will get integrate with Teamcenter also the CAD files will be stored in Volume(Vault). whenever we create any folder or item  in Teamcenter will get added in Oracle DB?? directly or first it will pass through VAult.
Re: How Teamcenter will get integrated with Oracle
@sam11 - Teamcenter will store the files only in the volumes but it will encrypt the file names. The Database will store the metadata about each object that is created in TC in the db - the properties, etc. The DB will also have the encrypted name and file location for each dataset stored but not the actual file itself because the file is in the volume. The FMS will direct the tcserver process to grab the correct file from the volume according to where the DB is telling it is stored and bring it back to the user. Does this make sense?
Jamie Griffis | PLM Solution Architect | Engineering USA
Builder
Builder
Hi @Jamie_Griffis
To understand deeply is their any pictorial represntation or the documents we can refer.
about integration process.
