How can we remove the release of a product to be accessible again?
Hi guys,
New to Teamcenter :)
I've released an item and of course it is read only.
What can I do to access that data and modify it again?
Cem
22 REPLIES 22
Re: How can we remove the release of a product to be accessible again?
1) Revise it.
2) Use Rel-Man utility to remove Status.
3) Write a one-step Workflow to remove status.
Thank you,
Larry Carpenter, P.E.
IT Architect, CAxPLM Applications - Siemens Molecular Imaging
Vice Technical Director, Board of Directors - PLM World, Inc.
CAD Grief Counselor
This message and any attachments are solely for the use of intended recipients. The information contained herein may include trade secrets, protected health or personal information, privileged or otherwise confidential information. Unauthorized review, forwarding, printing, copying, distributing, or using such information is strictly prohibited and may be unlawful. If you are not an intended recipient, you are hereby notified that you received this email in error, and that any review, dissemination, distribution or copying of this email and any attachment is strictly prohibited. If you have received this email in error, please contact the sender and delete the message and any attachment from your system. Thank you for your cooperation
Larry pretty much nailed this. If the issue is that you released something by accident you can roll back the application of that status either with a reciprocal workflow or using the release_man utility with the -unrelease action. More commonly you would revise a previously released item and author on the new revision which preserves the prior release for future reference purposes or as the revision others will use isolating them from the "noise" of a working revision being actively worked on.
“For something this complicated, it’s really hard to design products by focus groups. A lot of times, people don’t know what they want until you show it to them.” - Steve Jobs
Hi guys,
Thanks Larry,
I created a simple workflow to remove decrease the status and called it Unrelease :)
By the way where is the Rel-Man uitlity?
Cem
It's a command line utility called release_man most likely located in %TC_ROOT%\bin. I don't know for sure. Haven't used it in years.
Thank you,
CAD Grief Counselor
This utility was the only way in Teamcenter Engineering, with Teamcenter Unified Architecture you just use the unrelease option through a workflow.
The workflow doesn't force you to copy the revision to a special folder, which is needed for the release management utility.
Employees of the customers, together we are strong ;)
Hello, we are still stuck on Teamcenter Express V5 (and NX 7.5), and we also are currently without an admin. I have infodba access in the interim, and we recently found several Items that were accidentally released. These are Items (not IRs) and should've never been released. I'd like to remove or reverse their release status, and would really appreciate step-by-step instructions for creating this workflow.  Any help you have would be greatly appreciated.
KLINE
1) Login as infodba
2) Go to Workflow Designer app
3) File --> New Root Template
4) Pick Development Release on "Based on Root Template"
5) Delete these
6) Draw an arrow here between start and Status.
7) Delete the one called EPMSETSTATUS
8) edit the action on EPM-set-status to "DELETE"
That should do it
Honored Contributor
Honored Contributor
@CemAlpay that process will remove the release from the Item?  This apply for full on TC too?  I'm using TC 10.1, and could use something that will remove the release of Items, not Item Revisions, that shouldn't have been released.
-Dave
It should do that Dave.
