How do I know if a component in my assembly is the latest revision that is available in Teamcenter?
Basic question, Teamcenter 9 and CATIA V5.
If I am working on revising an assembly, and I have some random components that are loaded in my assembly that I want to check if they are the latest, Is there a feature in teamcenter that would allow me to check if these components are the latest in the database?
When I am revising something, I am revising a small part, so it is not feasible for me to check manually one by one if the other components are the latest released in teamcenter.
Thanks.
Re: How do I know if a component in my assembly is the latest revision that is available in Teamcent
Have you tried loading the Revision Rule "Latest Working" in Structure Manager and send to Catia?
Evaluating: AW 3.4
What if I have 'precise' as my revision rule. When I open my assembly, I want to know if the components in my assembly are to the latest revision?
If you use Precise, Your assembly may not pull latest, Try Imprecise and Latest working, You will all get all latest parts in CAD and BVE.
In you 3D environment I am not sure you can do that ( I can't in Solid Edge). As previously said , try with the revision rule settings, or check your Structure Manager for your assembly for the latest revisions.
Ciprian Chiosa
Solid Edge ST8 + TC10.1 - Win 7 x64
SIPA Enginnering Romania
