How do you map Attributes for NX and Teamcenter
In NX 6 and Teamcenter 8.1 it was really easy. Not sure how to do it in Teamcenter 9.1 and NX 8.5.
I used the command import_attr_mapping but NX 8.5 doesn't seem to recognize it.
5 REPLIES 5
Re: How do you map Attributes for NX and Teamcenter
same process.. nothing has changed. Works with nx85, tc91
In NX9 & TC 10.1 is this same process
Yes, same as before:
%TC_ROOT%\bin\import_attr_mappings -file=<your mapping file> -u=<your username> -p=<your password> -g=<your TC group>
Forgive me but,
I cannot for the life of me find an example of a mapping file.
Or some instructions on it.
New cadmin
Jason
First you need to use export_attr_mapping to generate the current mapping text file.
You will edit that to include your mappings.
The changed file will be imported afterwards.
The administration help for Teamcenter should have some examples.
Employees of the customers, together we are strong ;)
