How set session time_out by SOFT_TIME_OUT/Hard_Time_OUT?
I had installed J2EE & Weblogic Server and deploy a web-tier.
Set paramers like :
INFO  - 192.168.126.141.78963.Anonymous.00001 - 2017/08/06-07:01:11,760 UTC - PL
M - Global pool configuration:
        MANAGER_AVAILABILITY_INTERVAL=5000
        SOFT_TIMEOUT_EDIT=60
        PROCESS_MAX_PER_USER=1
        SOFT_TIMEOUT_STATELESS=60
        CACHE_CONFIG_PATH=TreeCacheTCP.xml
        HARD_TIMEOUT_STATELESS=60
        QUERY_TIMEOUT=300
        SOFT_TIMEOUT_READ=60
        HARD_TIMEOUT_EDIT=60
        ASSIGNMENT_MAX_CONNECTIONS=100
        HARD_TIMEOUT_READ=60
        MANAGER_AVAILABILITY_TIMEOUT=5000
        USER_TIMEOUT_STATELESS=60
M - Global pool config published.
After I login in as webclient , it's time out ,TC  Re-direct to the login page.But I login as 4-tier RAC ,it's time out ,I clicked a Item ,TC does not re-direct to the login Dialog,it assigned a new server.
How to confige to "Iogin as 4-tier RAC ,it's time out ,TC can Re-direct to the login  Dialog?"
Re: How set session time_out by SOFT_TIME_OUT/Hard_Time_OUT?
I see SOFT_TIMEOUT_STATELESS=60. Please increase to 1200 or atleast 600. All values are in seconds so give proper values more than 10 mins or so. Session is getting timeout in 60 seconds for you.
