How to Download Assembly File in TC include child
Dear Everybody
I have problem, how to download assembly file into local pc include child (Solidworks assembly file).
Thank You
TCSRP1
SW Integration 2015
NX10
Teamcenter 10.2
Re: How to Download Assembly File in TC include child
You need to do this from TC or direct from SW integration?
Best regards
Bernard Pacula,
CAMdivision Sp. z o.o.
Consultant PLM/System Architect
Mr. Bernard
I need just from Teamcenter into local PC, not direct from Solidworks Integration.
Is this possible??
Thank You
Sudikin
PLMexport will help here, but the assembly is not changed to use the native file names.
If the assembly should be usable in native, you have to export it inside of SW.
Employees of the customers, together we are strong ;)
If You want export all parts with assembly (easy, but not allways possible solution), then you can select all datasets (after i.e. search) and make Check-Out, but in options select Export Dataset On Check-Out like in attached pictures. After that - make Cancel Check-Out.
Best regards
Bernard Pacula,
Mr. Bernard
Thank you for your suggest, please more detail before check-out as selected all parts, etc.
Please provide with picture.
Thank You
Best Regards
Sudikin
Befor check-out you must find all datasets for select. Maybe you can assign all parts from this assembly into Project, and then do a Search for all datasets in this project.
Best regards
Bernard Pacula,
