How to Open 4G Design Elements into NX?
Can somebody tell me step by step how to open Design Elements from 4G Design in NX? Preferably the easiest way to do so.
Any help is appreciated, thank you.
3 REPLIES 3
Re: How to Open 4G Design Elements into NX?
Please have a look at the utility 4gd_populate_cd. It creates a populated cd from an existing structure. Guess this is the easiest way to get started.
xtof
Do you know where I can find this utility?
Usually it is just available on the server and 4GD needs to be installed. As user with no access to the utilities you must set it up manually but this needs a few steps. Have no time to describe it at the moment...
