How to Show Quick release
Dear All
I have a problem, how to show quick release in workflow template
Sudikin
NX10-TC11
SW Integration 2016
3 REPLIES 3
Re: How to Show Quick release
Probably it's a template filter aplied to this object...
Go to Workflow Designer > Edit Menu > Template Filter
At this window, choose the group, objetc and the Quick release to be available.
You need to set Template Filtering.
Login as DBA
Goto WF Designer
Edit->TemplateFilter
Select the group name which needs WF template and the object on which template is available (Itemrev)
Naveen Gowda
Mr. Naveen
Well Done, its works
Thank You
