How to approve all at the same time ?
Hello (Teamcenter)
How to approve at the same time the main assembly and all the subassemblies and parts underneath it ?
  • I now use CTRL+P to approve parts induvidually / seperately in a "down to top"-style .
Re: How to approve all at the same time ?
You can create a Snapshot of an Assembly from Structure Manager. This will put all the sub-assemblies and components into a flat list in the Snapshot. Then you can select all and approve at once.
Add action handler to workflow root start...
PS-attach-assembly-components -depth=ALL
You'll probably want a couple more arguments like:
-traverse_released_component
-exclude_released
Use in conjunction with EPM-attach-related-objects to get the BOMViewRevision and Datasets after adding components.
Evaluating: AW 3.4
