How to change the Logging Level in Teamcenter?
How many Logging levels are there? How can I change the amount of info that is been written in the Syslog?
Will it change the NX or SolidEdge Logfile too?
Thank in Advance
M
Re: How to change the Logging Level in Teamcenter?
There are different logging levels in Teamcenter like "DEBUG, INFO, WARN, ERROR or FATAL"
This logging level can be changed by setting these values to desired loggers.
Server side Properties file : TC_DATA\logger.properties
following loggers can be set for the desired logging level:
logging.rootLogger
logging.logger.Teamcenter
logging.logger.Teamcenter.Soa.Communication
logging.logger.Teamcenter.SOA.Tctp
This logging levels will be set at applictaion level, so it needs to be enabled separately for NX and solidedge.
Phani
