How to change the name of multiple dataset names, single or in bulk
Hi
Due to a recent issue we have uncovered where AWC 3.1 cannot download datasets that contain special characters, does anybody know of a method for us to change the name of datasets to remove the special characters?
We have over 1000 to do. They are all in a Released status.
Can we change the underlying dataset object name?  (Visible name vs object name)
Many thanks, N
Re: How to change the name of multiple dataset names, single or in bulk
You might be able to use:
install -find_control_chars infodba infodba dba WorkspaceObject object_name
And:
install -replace_control_chars infodba infodba dba WorkspaceObject object_name 07 ““
Using the Hex code of the illegal char. It's a little tedious providing Object/Attribute pairs one-by-one but it works.
Evaluating:AW 3.2
Sorry for the late response Randy.
Due to contractual reasons we are not allowed to change the dataset names. They must remain as provided to us by client.
I raised an IR, it has now been converted to a PR.
We use AWC 3.1 with IIS.  The issue does not seem to occur should we use JBOSS.
We are awaiting the feedback on the Problem Report.
