How to create EBOM in Teamcentert
Hello Community,
I created the product assembly which i required to manufacture. So i need EBOM for using in MPP(manufacturing process planner ) in teamcenter. Please let me know that how to create EBOM in Teamcenter for an assembly which is created in nx.
Thanks in advance.
Re: How to create EBOM in Teamcentert
Hi @GOLI,
NX assembly in Teamcenter is itself a EBOM. It will depend upon the requirement/process that how it is going to be used in the downstream processes.
Bill of Material Concept
Thanks for your valuable information. It is very informative and also able to understand about BOMs.But i also want to know one thing that i created the assembly in native nx now i want to import that total assembly with the structure how i created in nx  into Teamcenter .So i can define that as my EBOM in teamcenter.and please tell me how to define the imported assembly as EBOM in teamcenter.
Thanks for you valuable contribution for me.
Hi @GOLI,
Open NX from Teamcenter, File > Import Assembly into Teamcenter.
It will import the entire assembly into TC environment which you can review it by sending/opening it into structure manager.
