How to create EBOM in Teamcentert
Hello Community,
I created the product assembly which i required to manufacture. So i need EBOM for using in MPP(manufacturing process planner ) in teamcenter. Please let me know that how to create EBOM in Teamcenter for an assembly which is created in nx.
Thanks in advance.
Re: How to create EBOM in Teamcentert
Hi @GOLI,
NX assembly in Teamcenter is itself a EBOM. It will depend upon the requirement/process that how it is going to be used in the downstream processes.
Bill of Material Concept
Ganesh Kadole, QA Analyst (PLM), SQS
Testing: NX 11 | NX 12 | TCIN
TC 11.2 | TC Vis 11.3 | AWC 3.2
Thanks for your valuable information. It is very informative and also able to understand about BOMs.But i also want to know one thing that i created the assembly in native nx now i want to import that total assembly with the structure how i created in nx  into Teamcenter .So i can define that as my EBOM in teamcenter.and please tell me how to define the imported assembly as EBOM in teamcenter.
Thanks for you valuable contribution for me.
Hi @GOLI,
Open NX from Teamcenter, File > Import Assembly into Teamcenter.
It will import the entire assembly into TC environment which you can review it by sending/opening it into structure manager.
