How to delete objects from targets of Workflow process?
I need to delete objects (of Form type) wich related with ItemRevision via TC_Validation relation at the last step of my Workflow process. To delete - it mean delete absolutly, not remove( remove_from_targets) Each form has it's own owner, i can't delete this forms cause my tc_user has no such privilegue. Is it possible to delete objects in workflow, may be via change ownership before deleting? Do i need write my custom action hander for that or I can use base eamcente Workflow functionality?
3 REPLIES 3
Re: How to delete objects from targets of Workflow process?
You can specify separate ACL settings for the objects in a workflow without a handler.
Do this in the workflow properties dialog.
Employees of the customers, together we are strong ;)
But ACL settings reflect only TARGET objects, my Forms is not target objects. I start process passing ItemRevision as target. As I understand - ACL works only for target objects. Or I'm not right?
Have you tried if you really need to add the documents as targets?
I have never had to delete something with a workflow, so I cannot tell if this is working at all.
