How to enable BOM Window save for custom properties
Hai all,
I have some custom properties(created either in BOMLine/Item Revision) which is the operands of my ITK function. The save button would enable if I change the values of default BOM Line/PSOccurrence properties. But it requires to enable whenever I change my custom propeties to run the ITK function using BOMWindow_save operation. Please post a solution. And if you have some other operation please suggest me. Thanks in advance.
Re: How to enable BOM Window save for custom properties
Hello Anush,
I would like to dig a bit deeper to understand if you are looking to validate certain values on save of BOM window or you would like to acknowledge change of values on ItemRev custom properties?
IMHO:
I would be wary of changing the OOTB design of BOM window save (enable save).
It is a different use case to extend or validate values on BOM window save.
Harish
Harish
