How to release an item revision in teamcenter
I have an item revision and I would like to set its status "released". How this can be done in TCUA 10.1?
Anshu
1 REPLY 1
Re: How to release an item revision in teamcenter
You will have to use workflow to set / assign a status to item revision.
1) First, Make sure you have "Released" Status in the BMIDE
2) Assign Icon (If you require a custom one)
3) Create a workflow process template and using the "Set Status"
4) Select the Item Revision and initiate a workflow process and select the newly created workflow process template.
Refer Teamcenter Documentation for more information.
Hope this helps!
Cheers.
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
