05-13-2015 05:55 AM - edited 05-13-2015 07:07 AM
I have an item revision and I would like to set its status "released". How this can be done in TCUA 10.1?
Anshu
Solved! Go to Solution.
05-13-2015 05:50 PM
You will have to use workflow to set / assign a status to item revision.
1) First, Make sure you have "Released" Status in the BMIDE
2) Assign Icon (If you require a custom one)
3) Create a workflow process template and using the "Set Status"
4) Select the Item Revision and initiate a workflow process and select the newly created workflow process template.
Refer Teamcenter Documentation for more information.
Hope this helps!
Cheers.
