How to release an item revision in teamcenter
HELLO,
i have a question,
how to release an item revision in teamcenter.
for example 3D is present in the teamcenter with baseline revison 0003, i would like to relase 0004 how can i release 3D with 0004 baseline..
please advise.
Re: How to release an item revision in teamcenter
You should use workflow to set / assign a status to your baseline item revision
 Create a quick release workflow process template and using the "Set status"  and select the Item Revision and initiate a workflow process and select the workflow template which you created
I have attached the screenshot, check that
Got it,
Thank you so much
