How to see multiple versions of an item revision
Teamcenter 10.
I believe that our system is set up to save 3 versions of each item revision.  When I look at the item revision in My TC, I only see one version.  What do I have to do to see and access older versions of an item revision?
Thanks.
9 REPLIES 9
Re: How to see multiple versions of an item revision
@DaveL3149
You can use the OOTB query "Item Revision" to get the results
Rafa
The key word that you are searching for is sequences for Item Revisions (shown by @Rafa2 as ";1" after the revision id). And to clear previous IR sequences, use Purge.
Evaluating: AW 3.4
I probably should mention that I am not a system administrator, along with being fairly new to NX and Teamcenter.
So, to test the methods you explained:
I created a new part in NX, basically a rectangular block.  And saved it.
Then I added a hole and saved again.
Then I added another hole and saved again.
I did not do a file/save as in NX.
I then did the search in Teamcenter as described by Rafa2, but only one version is showing up - the latest saved version.
So, how can I get back to the orignal saved part, a block with no holes?
Or is that not possible?
Hi Dave, You are describing Dataset versioning (saves) while Item Revision sequences are only created by check out/in of the IR. If you select the DS and then File > Open... you will be able to select the DS version from the pulldown.
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help#uid:xid1256818:index_my_teamcenter:xid1020...
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#uid:mytc_dataset_open_spec_ver
Evaluating: AW 3.4
(view in My Videos)
NX (v17 - 1872) | Teamcenter (9 - 12)
Honored Contributor
Honored Contributor
@BenBroad is there a way to dave that video?  I have some users that would benefit.
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
Problem solved.  Thanks to everyone for the help.
Hi @DaveK,
I've attached the movie.
Regards, Ben
Honored Contributor
Honored Contributor
Thanks @BenBroad
-Dave
