How to share a PFF with other users
I have created a search results PFF but can not figure out how to share with other users.
With Queries, I can change ACLs but I cannot send the PFF to My Teamcenter in order to access the ACLs.
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
4 REPLIES 4
Re: Hot to share a PFF with other users
Did you create the PFF as dba? some objects are automatically Public when owned by the DBA group.
You can create a query to find PFFs, then in the results you can Send To Teamcenter:
Tricia Crichton | Software Architect | SEAL PLM, Inc
@TCrichton   Thank you much...   Unfortunately, I did create the PFF as DBA but it does not expose to other users.   2ndly, Thanks for the Query hint,  THis did allow me to send the PFF to My Tc... but again, no luck as from here I still an not get to the Access option of the RMB quick menu...
Matt Johnson
Teamcenter 10.1.7
Hi Matt,
There's another command for Access on the top button bar:
-Tricia Crichton
OH WOW!!!   Back to the Basics!!!  If it were a snake, I'd have been bitten!
Problem solved!!!
THANK MUCH!
Matt Johnson
Teamcenter 10.1.7
