How to show who reviewed and signed off the item revision?
In Teamcenter how do I show who has reviewed and signed-off the Item Revision?
If the Item revision goes through select sign off and perform sign off and the work flow completes? After completion, how do I show the who signed off the item revision?
3 REPLIES 3
Re: How to show who reviewed and signed off the item revision?
You can select the release revision & switch to "Process History" tab. There you can see the workflow task & reviewer details.
Thanks Kalpesh
But its not on the part revision. Its still on the fnd0WorkflowAudit object. If I send this part to NX I am not able to map the approval attributes like signoff date, user name etc
@PLMSprint wrote:
Thanks Kalpesh
TcUA Workflow Attribute Mapping examples
Project SignoffDate :ItemRevision.Job.SIGNOFF(Checker,Project Engineer).decision_date /master=iman /description="Project Signoff Date"
 Checker: ItemRevision.Job.SIGNOFF(Checker,Project Engineer).group_member.user.person.user_name /master=iman /description="Checker"
Status : ItemRevision.release_status_list.name /master=iman /description="Status"
ORIGINATOR : ItemRevision.Job.SIGNOFF(Originator).group_member.user.person.PA7 /master=iman /description="Originated By"
ORIG_DATE :ItemRevision.Job.SIGNOFF(Originator).decision_date /master=iman /description="Originate Date"
