How to use JT instead convert Multicad datasets in NX assembly
I would like to use JT files in NX assembly without convert from Multicad datasets. Every time NX opens or uses files from another cad system in Teamcenter, it creates a new ".prt" dataset which brings low performance.
Re: How to use JT instead convert Multicad datasets in NX assembly
That behavior is controlled by a NX Customer Default setting; 'Add NX Datasets' under the Teamcenter Integration for NX...Parts without NX Datasets tab. Set it to 'Never'.
Larry Carpenter, P.E.
