How to use VisDispClearanceMngr for clearance check
We used VisDispClearanceMngr class to determine two parts are interfered or not. But the problem is every time it will pop up the clearance result window, which is very annoying. Do you know any way we can disable this pop up window through the API? Also can we leverage the functionality of clearance result window through API. Instead of double click the result line to view interference detail, we want to drive it through API? Appeciate your help.
