I cant delete some workflows
Not with the owner user but neither with infodba with bypass. This happen with very few of them, normally we can delete workflows without problem. How can I delete them? Maybe these workflows are corrupted.
Re: I cant delete some workflows
Do you see a specific error when you attempt to delete the workflow... say references or workflow is referenced etc?
You could use verify_tasks with list mode to list corrupted workflow job.
Harish
