I possible to know how many items there are inside a folder
HI, I have the need to count the number of item that are inside the solutions folders inside a change request.
By now I count it manualy, I wonder if there is the possibility to show someware the number of items inside a folder.
Re: I possible to know how many items there are inside a folder
I do as, Select the first item in folder > Hold SHIFT key > Select the last item in folder > CTRL+C.
It will show the total count of copied items in the clipboard icon usually located at the right bottom corner of TC.
As a alternative, i use below option.
1. Select the 'Solution Items' folder and go to 'Details' tab. The tab shows the list of objects under 'Solution Items' folder.
2. In the right corner, select 'Print Table' --> HTML/Text.
3. In the resultant window, you can see the object count just above the table.
