cancel
IPEM is not picking server details from client_specific.properties
Versions:
TC version 9.1.2.x and Creo2
IPEM 9.1
Setup Details:
Client system has two 4T rich client (separate portal root install directory) configurations deployed through OTW installation
1) TC 9.1.2.4 IPR1- Connection to (a) Production and (b) Test instance servers [non-CAD PLM environment]
2) TC 9.1.2.7 IPR2 - Connection to (c) CAD Integration server configured for IPEM with Creo2
Problem:
When Creo2 is launched with IPEM integration, the database connection to 1(a)-Production is displayed!!
There is no entry for 1(a) in the client_specific.properties file of IPR1
However, there is an entry for CAD Integration server 2(c) in client_specific.properties of IPR2
We have explored entries in IPEM directory within xml/config/dat/property files but unable to find the configuration that is creating this problem
Please share your valuable suggestions. Appreciate and look forward to a quick response.
