Is is there a way to configure BMWriter to generate custom XML format ?
 We have a Thirdparty integration where receiving system can not read PLMXML file. It reads plain xml file only. Is there a way to configure BM_Writer to generate plain xml with few properties for entire bom? BOM has approximately 3000 lines
Re: Is is there a way to configure BMWriter to generate custom XML format ?
from my understanding there is no way to configure BOMWriter to write in another xml format. You have to write your own xslt to transform plmxml to customer specific xml.
Thank you. Even I was suspecting the same.. Write custom SOA solution to extract only required attributes in custom format. However performance is on lower side.
