03-29-2017 02:15 AM
04-03-2017 05:05 AM
It is not possible to access TC from outside network unless you are connected to the company network using VPN.
Ganesh
#IngenuityIsNX | NX - What's New
04-06-2017 09:16 AM - edited 04-06-2017 09:17 AM
If the web port is open you should be able to access Teamcenter from a web browser by using its URL. (As far as Teamcenter was configured to give service over the web). Just append /tc/webclient to the server's address.
https://[server]/tc/webclient
04-06-2017 09:24 AM
@PLMFan wrote:If the web port is open you should be able to access Teamcenter from a web browser by using its URL. (As far as Teamcenter was configured to give service over the web). Just append /tc/webclient to the server's address.
That would be thin client, Right...?
Ganesh
04-06-2017 10:01 AM - edited 04-06-2017 11:23 AM
That is right :) But also the Rich one, it uses the same ports.
04-06-2017 01:25 PM
Evaluating: AW 3.4
04-06-2017 02:33 PM - edited 04-06-2017 02:35 PM
Randy is right, be like Randy.
In general, publishing military or industry data even through secured ports is really very risky. Anyway, in Mad-Max scenarios communicating with Teamcenter using well known ports is perfectly possible and I deserve many Kudos for my answer.
