Is there any way to count BOM items?
Builder
Builder
How do we count BOM items ? Is it possible with query builder?
Re: Is there any way to count BOM items?
I could think of couple of ways:
[1] With customization you can get the count of BOM Items for sure.
[2] Extract the data from structure manager into an excel for count
[3] In TC8.3, I remember BOM PS Report for Part structures ...maybe that will help for count (if the report works)
[4] Using structure Manager --> Find in Display UI (can be found below in the structure manager) --> set Property name to 'Item Type' and include search value to the item type (part, design etc) that constitutes your structure --> Hit find button and it should display the bom count.
Best Regards
Harish
The easiest I could think of is StructureManager->ExpandBOMStructure->SelectALL->Copy.
From clipboard (ExtremeRightBottom-NotepadIcon) you can see number of items copied.
Make sure you clear clipboard before next copy Smiley Happy
Naveen Gowda
Builder
Builder
Builder
Builder
@HarishVenkat
Thank you
