Issue with dll creation in ITK customization
We are working in TcUA 11.2.with  Visual Studio  2012 prof verison for ITK customization. We are able to generate dll with sample code (first time). When we tried to compile code for actual customisation (BOM  line calculaiton), dll file is not getting created. We are not able to identify the reason for this.
Pl help.
Regards.
Re: Issue with dll creation in ITK customization
This info may not be sufficient to tell about the reason/solution to the problem.
But I'd suggest to have minimum supported version of Visual Studio.
TC11.2 supports MSVisual Studio 2012 Update 1 Standard & Professional Edition with hotfix KB2781514.
Builder
Builder
Can you share the errors?
