cancel
LSD attribute in Teamcenter 11
Hi!
Do you know how to find the attribute, showing the date when the revision was sent or uploaded to our database in Teamcanter 11? In Teamcenter 8.3 it was called LSD, but I can't find it in 11 version.
Re: LSD attribute in Teamcenter 11
In Teamcenter11 I still see Attribute "lsd" on ItemRevision. display name = Last Saved Date
Cant find it, neither in English nor in Russian... May be because we use Russian localised version?
You are right, even I can't see in RAC. My last response was based on BMIDE.
But now I see that the property constant "Visible" is set to false in BMIDE.
Finally got it, thank you very much!
Found that the attibute LSD in TC11 works different from the same attribute in TC8.3. When I sent via datashare or upload revision from database1 to database2 LSD in TC8.3 shows the date when the revision was renewed in database2. But now the same attribute LSD in TC11 shows the date when the revision was saved in database1. So these are different dates. I need to be sure that the revision was sent into database2, so I checked in TC8.3 that it was renewed, and I used the attribute LSD to check it, but don't know how to do it in TC11.
