License Monitoring T4EA, SAP_Gateway
Hi Everybody,
I would like to know wether it is possible to view the current Licenses in use for the T4S interface.
Thanks in Advance!
M.
Re: License Monitoring T4EA, SAP_Gateway
Do you have access to the BGS Admin GUI (default http://localhost:45400) or the GS Admin GUI (http://localhost:45410) default t4adm\geheim (German for secret)? We used to monitor licensing through that however I think it has been off-loaded to flexlm so you may need to review that log instead (or "lmutil lmstat -f <feature_name>").
Thank you @RandyEllsworth
Do you know how the feature T4S is called?
I do not own a license for T4S and don't know the feature name.
