Lifecycle Visualization floating components
Hello all,
I've been experiencing this issue with Vis for quite some time now, and am struggling to find a resolution.  When viewing an assembly, large or small, its rather consistent that some of the components will be off floating in space and obviously in the incorrect location.  Has anyone else experienced this before? If so, were you able to fix it or find out why this occurs?
any input is appreciated!
Thanks in advance!
Jake
Re: Lifecycle Visualization display incorrect
Also,
I'd like to add I am using a BASE level license.
Jake
