11-22-2017 01:45 AM
Is there a way to increase the text size of meassures? A workmate has a problem because in his workstation numbers are too small. Thanks in advance.
Solved! Go to Solution.
11-25-2017 05:11 AM
here an possible way. This changes not the general settings.
If you need it for general settings go to the buttonbar measuring there is to find the button for measure setting in general use.
best regards
Wolfgang
11-27-2017 07:55 AM
Thank you Wolfgang! It worked
