Lizenz
As an Admin:
1-How can I know which Kind of License I have for each user?
2-How many Kinds are there anyway?
3-Can I simply swap a user to inactive and simply get his license for other user?
4-Is there a history or Log for a user to see how often did he swap between active and inactive?
Thanks in advance
Greetings!
Re: Lizenz
if you have access to license server you can run the lmtool.exe and check the licenses.
or you can use
lmutil  lmstat  -c 28000{License Server Host}
As a admin if you have Teamcenter login and dba group, then you can active/inactive users.
