Logging level of Active Workspace
I would like to know wether Active Workspace writes an undependent logfile, or is it in tcserver***.log integrated.
How could I increase the logging level of just Active Workspace.
Thank in advance!
Re: Logging level of Active Workspace
Active workspace will also write the same tcserver.exe*.syslog files.
Active workspace has same debug levels that of Teamcenter - "DEBUG, INFO, WARN, ERROR or FATAL"
This debug level can be set in %TC_DATA%\logger.properties
Loggers available as of Active workspace 3.2.1 listed below.
logging.logger.Teamcenter.ActiveWorkspace.awp0aws2.Solr=DEFAULT
logging.logger.Teamcenter.ActiveWorkspace.awp0aws2=DEFAULT
logging.logger.Teamcenter.ActiveWorkspace4G.Fgd0aw4gdesign=DEFAULT
logging.logger.Teamcenter.ActiveWorkspace4G.Fgf0aw4gfoundation=DEFAULT
logging.logger.Teamcenter.ActiveWorkspaceBom.Service=DEFAULT
Phani
