Login Error
Whenever I login into Teamcenter it says:
ITK_internal_error: Unclassified error/exception. See system log file for possible explanation.
The log file says that:
Caused by: com.teamcenter.schemas.soa._2006_03.exceptions.InvalidCredentialsException: ITK_internal_error: Unclassified error/exception. See system log file for possible explanation.
I don't understand. The credentials are correct but I am still getting the same error.
Re: Login Error
Re: Login Error
Please, check that the database service used by Teamcenter is running properly. I faced that situation once and it ended up being an SQL Server corrupt database. Good luck.
Re: Login Error
please check mentioned points are working properly or not
1)TC and Database(SQL, Oracle) connectivity.
2)Listener (in the case of oracle),MS-SQL service(in case of sql).
Re: Login Error
Thank you bhanu112!
