MENCMachining Item created using one role, Read-Only to other role on same group
Builder
Builder
  Good Day. Mfg Process Planner creating MENCMachining item with NX datasets for CAM. Later NC programmer opens the part in NX Manager to create CAM operations, But part opens in read only mode in NX Manager. But both roles Mfg Process Planner & NC programmer belong to same group (Supply Chain).
 Do you anyone have idea why NC Programmer gets read only part, Even though both belong to same group.
MENCMaching attached to Project.
 Note :  We couldn't got any solution for this IR from GTAC.
Thanks in Advance,
PradeepECR
PradeepECR
NX7.5 TC8/ NX9.0.2.5 TC10.2
Re: MENCMachining Item created using one role, Read-Only to other role on same group
We have had similar problems,  try the following workaround.
The person who /role that created the MENC machining need to logout before the next person can edit, otherwise it is locked by that user.
Builder
Builder
Thanks for your Inputs. I will check it in my environment & update you.
PradeepECR
