MS Office integration: How to save as an Item instead of dataset?
From the Teamcenter menus in MS Office, I can save MS Office doc as Dataset. How to save it as an item ?
Re: MS Office integration: How to save as an Item instead of dataset?
Sorry for polish language on screen, but you should make two steps:
1. Create new item (New -> Item).
2. Save dataset into this item (Save As -> Dataset).
Best regards
Bernard
Best regards
Bernard Pacula,
CAMdivision Sp. z o.o.
Consultant PLM/System Architect
Thanks for your response! Though we were looking to Save As Item with attached dataset in a single command, this would also work.
