MS Word Export/Report
Hi all,
just a simple question..
Target:
MS Word Report of a BOM (Requirements Specification) excluding some BOM lines.
Question:
Is it possible to create a Report based on MS Word Templates (not XML) that excludes some BOM lines according to a property value?
I set "Dynamic.TM.my_tm" in the SpecTemplate and defined a Transfer Mode to filter the BOM, but it doesn't work.
So...is it possible to export only objects having for example the value "Active" in a certain property? If yes, what is the way, what is Transfer Mode/Closure Rule?
Thank you so much!!!
Re: MS Word Export/Report
I think you'll need code to solve this problem.
Evaluating: AW 3.4
