Manufacturing Process Planner - Custom Report
Is there any way to gerenate a report where all the parent items are displayed in the same row starting from a particular level?
Normally the structure looks like this.
Level 0: Item A
Level 1: Item B
Level 2: Item C
Level 0: Item X
Level 1: Item Y
Level 2: Item Z
I want to generate a report similar to the one below. The parent of the previous column will have to be displayed in the next column.
1. Item C        Item B         Item A
2. Item Z        Item Y         Item X
Ganesh G.
Re: Manufacturing Process Planner - Custom Report
I've heard of a two column report (flattened BOM):
  • A and B
  • B and C
  • X and Y
  • Y and Z
But not a three column report? You might need custom code for that kind of formatting.
Thanks for the reply. It is not just a three column report. The columns may increare based on the level I need. I am also looking into the scripts/ codes. Thanks again.
