Mass measurement in Lifecycle Viewer
Hi guys,
Suppose we have an NX part having 2 solid bodies in one part.
When we try to measure the mass, part summation sees the whole part.
Is it possible to pick one model and see it's mass in Lifecycle Viewer?
Cem
Re: Mass measurement in Lifecycle Viewer
Two solids in one model is invalid. Same as solids in an assembly. Yes you can do it but it breaks functionality.
Evaluating: AW 3.4
Yeah, I believe it does.
It is not for general use.
They want to be able to do this.
Can you tell me how it's done?
Cem ALPAY
Üçgen Yazılım Ltd. Şti.
--Mobil cihazımdan gönderildi--
Delete one of the solids, perform your mass calculation, then undo (just don't save the part).
Evaluating: AW 3.4
I was looking for a solution just inside Lifecycle Viewer. Not in NX.
Cem ALPAY
